Displays the current TACACS+ accounting client configuration and statistics.
N/A.
TACACS+ Accounting—The current state of TACACS+ accounting, enabled or disabled.
TACACS+ Accounting Server Connect Timeout—The amount of time configured to detect and recover from a TACACS+ server failure.
The name of the primary TACACS+ accounting server.
The IP address of the primary TACACS+ accounting server.
The TCP port to use to contact the primary TACACS+ accounting server.
The IP address and VR used by the switch.
The shared secret configured for the primary TACACS+ accounting server.
Secondary TACACS+ Accounting Server—Contains the same type of output as the primary TACACS+ accounting server for the secondary TACACS+ accounting server, if configured.
The following command displays TACACS+ accounting client configuration and statistics:
show tacacs-accounting The following is sample output of this command: TACACS+ Accounting : enabled TACACS+ Acct Server Connect Timeout sec: 3 Primary TACACS+ Accounting Server: Server name : IP address : 10.201.31.238 Server IP Port: 49 Client address: 10.201.31.85 (VR-Default) Shared secret : qijxou Secondary TACACS+ Accounting Server:Not configured
